Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Aftermarket exhaust question..  (Read 889 times)
Offline James.Wray89
« on: Jan 06, 2019, 07:01 PM »
Hey guys,
So I recently fit the full Delkevic exhaust system with downpipes and just have a quick question.
When I initially start the bike up there's a small bubble noise that I can hear kind of more like a gurgle not like a bubble gun, but once the bike has more less warmed up it goes but then when I pop the bike in neutral and pull back on the throttle when the rev drops there's a very small bubble noise that I can hear.
Is there anything to worry about? Maybe it's worth me having a look at the clamps and make sure everything is all sealed over the small holes where pipes meet. Or is this normal for after market exhausts?
James Wray
Re: Aftermarket exhaust question..
« Reply #1 on: Feb 11, 2019, 01:18 PM »
Still making a small bubble noise  :004:
Anyone got any advice? i may have a little look tomorrow and undo the exhaust/downpipes and have a jiggle.
James Wray
  • Bike: Mk1V650 & Mk2V1k
« Reply #2 on: Feb 11, 2019, 02:45 PM »
*Originally Posted by James.Wray89 [+]
Hey guys,
James
It is call "Character"  :008:
Richard  :001:
Offline 100milesaway
  • City / Town: Leyburn
« Reply #3 on: Feb 11, 2019, 02:54 PM »
James
Richard  :001:
  And it will drive you mad.    :125:
What would you rather be, or a wasp?
« Reply #4 on: Feb 11, 2019, 04:59 PM »
As long as its normal, I'll deal with it.. For now. Until I venture to a 4 cylinder :P
James Wray
Offline Dilbert
  • Bike: Tiger 800 XRx
  • City / Town: Holmes Chapel
« Reply #5 on: Feb 12, 2019, 12:58 PM »
popping, crackling and a low rev burble is a common symptom of a less restrictive to airflow aftermarket exhaust, the increased airflow tends to make the low revs run lean, if you want to you can have the bottom end retuned to enrich the mix, without affecting the rest of the range, needs to be done on a dyno for best results.
As Towerman, it's quite pleasing in a way and certainly nothing to worry about, I had it with my Versys(s) and ran a Tiger 800 for at least 30,000 miles with the same snap, crackle and pop  :028:
Just passin' through
Offline cl6118rd
« Reply #6 on: Feb 12, 2019, 02:12 PM »
James
Richard  :001:
Never heard 'character' ever associated with a Versys before.  :001:
« Reply #7 on: Feb 12, 2019, 02:42 PM »
*Originally Posted by cl6118rd [+]
A bit harsh.....even a dumper truck can have character.    :107:
Offline fr499y
« Reply #8 on: Mar 25, 2019, 12:11 PM »
i miss the crackle pop and bangs from my old XJR, that thing was like a machine gun going off. ( older carbs, 4-1 200mm big bore can :D )
As already said, you'll get a bit of a pop every now and again with an after market exhaust. Some bikes do it more, some do it less. You'll find because the fueling is cut on throttle close, you'll just get a small pop. Some bikes that are remapped or different fueling will throw fuel in on closed throttle.
