Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Fitting Brembo Callipers  (Read 10442 times)
Offline Krisnow
  • City / Town: Ko Samui
  • Country: th
Re: Fitting Brembo Callipers
« Reply #30 on: Feb 26, 2021, 10:07 PM »
Kris
Thanks for the info on the 17mm Radial being best  :028:
What difference does the 18mm vs 20mm pump lever ratio make to the OEM calliper setup feel like  :question:
Richard, I guess with the Tokico, I would use 20, but with Brembo I use 18.  the difference is subtle.  18 gives you more modulation but longer lever travel.  I have Corsa one, so I have additional Normal/Sport/Race adjustment, which corresponds to the point where the brake engage; frankly speaking, I hardly see any difference.  the regular RCS is good enough.
Offline Krisnow
  • Country: th
« Reply #31 on: Feb 27, 2021, 01:42 AM »
it is not fair to say that the Tokico callipers 'suck'.  they are much better than the floating Nissin.  but I got used to the Brembo ones, which have much stronger braking power.
