Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Bike Paddock Stands - or straight for centre stand?  (Read 6357 times)
Offline anderson
  • Bike: Mk2 650 2013
  • City / Town: Cornwall
Re: Bike Paddock Stands - or straight for centre stand?
« Reply #20 on: May 08, 2021, 04:03 PM »
I will echo Gustavo here. I had a stand with the flat parts (from my old bike). But when i tried to use it on the versys it just doesnít work at all because of the versys swingarm shape.
I very quickly went and bought a new stand that works with bobbins. I used some bolts instead of bobbins. Although being a skinflint means the stand scratches the near side swingarm. I now see why bobbins are used.
« Last Edit: May 08, 2021, 04:04 PM by anderson »
It is easier to ask for forgiveness than permission.
Offline Micklel
  • Bike: Versys 650 ABS
  • City / Town: Stamford
« Reply #21 on: May 08, 2021, 04:42 PM »
Thanks for responding.  Yes thatís the one & I have the forks & bobbins fitted, I admit thereís a knack to it but I think you need to lift the bike at the rear with your left arm whilst pushing with your right.  I failed to mention that since buying the stand Iíve a tear in my left rotator cuff & have lost a lot of strength in my left arm.  Just want something that I can slide in easily & push down 🤔😕
Honda c50, Honda CB175, Yamaha RD250, Suzuki GT750, Suzuki GS1000E, HD1200 Sport, Yamaha Fazer 600, Kawasaki Versys 650 ABS
Offline Micklel
« Reply #22 on: May 08, 2021, 04:45 PM »
A quickie, you canít use the pads with the ABS Versys as thereís a cable running under the swinging arm.
« Reply #23 on: May 08, 2021, 04:54 PM »
I almost forgot.  There is always a forward handle rear stand as an easier to operate option:
https://www.pit-bull.com/spooled-forward-handle-rear-motorcycle-stand-f0043-000
Pit-Bull stands are not cheap (and less so if you have to ship across the pond), but they are very well made (I have a couple in the garage).  There may be knock-offs that are cheaper, especially if they are in stock in the UK.
Online 100milesaway
  • City / Town: Leyburn
« Reply #24 on: May 08, 2021, 05:47 PM »
*Originally Posted by Gustavo [+]
Yep, ya can't beat a pit - bull in your garage.    Way better than alarms.  :whistle:
What would you rather be, or a wasp?
Offline Micklel
« Reply #25 on: May 08, 2021, 06:07 PM »
Cheers, never seen a forward spool stand although in the video he made the normal stand operation look like a piece of cake 🙄
Offline anderson
« Reply #26 on: May 08, 2021, 08:13 PM »
I bought this for my V a month or so ago.
Works fine. Doesn't require a huge push and the bike is picked up from the side stand and up onto the paddock very smoothly. No fear of it going over. Just make sure the bobbins are aligned before you push.
https://www.ebay.co.uk/itm/232729409115
Offline Micklel
« Reply #27 on: May 08, 2021, 08:58 PM »
*Originally Posted by anderson [+]
Thanks will take a look at it 👍
